November 23, 2024, 05:53:03 am *
Author Topic: Help for frame buffer size  (Read 8856 times)
rankena
« on: January 01, 2010, 05:38:30 pm »
What is the best frame buffer size settings in Asus M2NPV-VM bios for xxHE?Possible options for change:Disable->16->32->64->128->256? unhappy
« Reply #1 on: January 01, 2010, 07:07:15 pm »
I don't know, sorry !
rankena
« Reply #2 on: January 02, 2010, 10:25:59 am »
Anybody can help me?Moritz,AUDIODIDAKT maybe something can recommend?
« Reply #3 on: January 02, 2010, 11:33:20 am »
If you can recognize this is for audio, the lower the better for SQ. Also, you may try 32 and *if* it is for audio, you probably won't be able to play (ticks or just distorted sound (no loud static). So, you then can slowly set it higher until no distortions can be heard.
rankena
« Reply #4 on: January 02, 2010, 01:51:20 pm »
ok.I experiment with this.
Page created in 0.146 seconds with 19 queries.
