November 22, 2024, 03:07:19 pm *
Pages: 1 2 [3] 4  All
Author Topic: Windows7 ? hmm ... maybe not !  (Read 60849 times)
« Reply #30 on: January 07, 2010, 08:48:36 am »
I'm considering back-revving Windows from Windows 7 to Vista based on the reports of superior SQ with XXHE.
Just wait a bit until the upcoming weekend. Engine#4 only brings me joy - and this is under W7 ...
« Reply #31 on: January 07, 2010, 11:34:47 am »
Hi Peter. You mentioned in another post that Engine 4 "should" work in Vista; have you had an opportunity to test it in Vista? Just wondering.
« Reply #32 on: January 07, 2010, 01:15:05 pm »
It does. But notice that when I tested this, this was just the sound engine and not the device selection. This is ready now and *that* has not been tested in Vista. But there is no reason it won't work in there. However ...
In XP it does *not* work yet (the device selection) because I miss some Registry keys there. I just finished Googling for a few of hours on this, but nobody seems to miss those keys (while I have a couple of (HP) XP machines, and they all lack that key). Wait, I still have it under ctrl-v I think :
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\
If that is in Vista, it will be fine.
« Reply #33 on: January 07, 2010, 01:48:00 pm »
Yeah, it's in Vista. Am hoping to finally use the Hiface usb/spdif converter ( http://www.m2tech.biz/products.html ). It currently shows up in device manager but not in sounds under control panel. Am hoping it shows up in xx engine 4 in settings. Sorry about going off topic.....
« Reply #34 on: January 07, 2010, 02:12:31 pm »
Ok OffTopic Happy
Ah ... it is good that you mention that (again) ...
As how it is now, no, it won't work. Why ? well, because I take the devices from the control panel as base. If not there, no go.
Btw, I planned to do this otherwise (like taking something in the Registry as a base) but in the end could not proove that would bring more devices (for Kernel Streaming). Yea, wrong ones ! And I guess for your USB device it won't be different. But (and I thought you might have sent it back afterall because of the long wait) :
I have read that the first 100 units (seen by serial number perhaps ?) were faulty. I can't be sure it was about this aspect, but on the same forum I sure read about people having the same issue as you have !
So, maybe you can check this with the manufacturer ?
Uhm ... but wait. I also have read that Kernel Streaming plays. I think even you said that ?!
Ok, if that is true it must be possible to provide functionality which lets you add your own devices (my before plan).
... no wait ... you will be able to do that already (just for testing) : Change the name of a random sound device you don't use (Loudspeaker Icon in Taskbar Tray - Device Properties - topmost field) into what this needs, and it will work.
First you must have 0.9y-5 though and a log which will show you the discovered KS devices.
« Reply #35 on: January 07, 2010, 02:39:22 pm »
yes, I can get it to work now with Media Monkey even though it does not show up in control panel/sounds. Will wait for 9y-5 to see if it can be configured to work. I didn't return it cause M2tech told me they would have a WASAPI driver out this week-- still waiting-- and this other guy told me he'd have kernel streaming out in xx in January.....looked like a win win to me, though it has been an exercise in patience!  Happy
DannyD
« Reply #36 on: January 11, 2010, 04:48:46 pm »
When you wrote "upcoming weekend" for the release date of Engine 4, I assume now that you meant the weekend of January 16 and 17.  Is that right?  I'm a little confused because I've seen in your signature that you're using Engine 4 already.  I'm anxious to give it a try since my music server runs Windows 7. (By the way, far be it from me to nag about software delivery dates.  I've missed more than I've had hot breakfasts!)
Dan
« Reply #37 on: January 11, 2010, 05:32:37 pm »
Yeah Peter, when we gonna get the new version, for God's sake? I sat next to my PC waiting for it all weekend...
... It had better be good!
« Reply #38 on: January 11, 2010, 06:25:33 pm »
Hey Mani, you weren't the only one sitting by the pc, waiting. Only thing I can figure is our guy is being careful with this release. Imagine having to deal with all the issues that come up for a "stable" release. So I continue to look to those strained pools of S-T-R-E-T-C-H-E-D patience.  Happy Happy Happy
« Reply #39 on: January 11, 2010, 06:44:20 pm »
I'm glad somebody asks, because I'm not much used to say I'm late with software ...
I too sat next to my PC the whole weekend. And Friday, and today. All with the same stupid subject ... timings.
I just startedplaying through the loudspeakers (most testing can be done without sound) and my son asked "is it really to begin ?" with that referring to the normal playing of music which starts around this time every day (6-7pm). My respons : "I only need to hear things now because I think it works. Same as yesterday, some 24 hours ago ... swoonswoon".
Two days ago I had it all working, but then it appeared that my Unattended testing wasn't sufficient to let it really work. I mean with Attended things have to be properly synchronized with the UI, and there nothing worked. Ok, it explained some anomalies I saw with the OSD Time at Unattended but ... in fact it was one big mess.
But now AT LAST I just ran trouble free through the last half of The Wall (gapless) at Attended, and it looks like all works now. So, now back to Unattended to see what happens there ... Should be okay, but it really needs a few albums to run through all the combinations.
Btw, when two days ago nothing would work anymore I was "forced" to use Engine#3 again, but man, got I used to Engine#4. Everything shouted to me, especially Jim Morrison and John Fogerty (but they have "similar" voices) so I thought to play something "technical" which became Ben Harper with Welcome to The Cruel World. Well, that still worked.
I may think that I can put it all up tonight, but I probably won't make it because of the Release Note stuff.
AND : Don't be over-enthusiast because nothing tells at least me your soundcard etc. will be able to use Kernel Streaming. For instance (Russ) a Juli@ does not. Not over it's SPDIF output. Maybe if the "Loudspeakers" can be rerouted to SPDIF, but don't have hopes.
Well, by I'm into the 4th track Unattended, and all still looks good.
Sorry for the waiting and sorry I didn't say anything yesterday.
Per
Music is forever...
« Reply #40 on: January 11, 2010, 09:31:38 pm »
Thanks a lot Peter, for taking time to tell us about your struggles. You don't have apologize for anything....
To me this sounds like a major update. Perhaps you should consider calling it version 0.9z instead? By the way: Would it be an idea to make a pre-release to a few experienced users in here first to catch the most obvious bugs before it is released to the public? To minimize your workload. Just a suggestion.
Good luck - we can('t) wait....  Wink
Per
Sep 2010
« Reply #41 on: January 11, 2010, 10:29:37 pm »
Ditto.
Absolutely no need to apologise. You know, I really could live with 0.9y-4 indefinitely. But of course, if there's something 'better'...
jkeny
« Reply #42 on: January 12, 2010, 02:10:33 am »
I know this is a Windows 7 thread but is 0.9y-5 also available on XP? I thought I read somewhere that it was but can't find it now!
« Reply #43 on: January 12, 2010, 02:25:27 am »
I think you mean this,
http://www.phasure.com/index.php?topic=1007.0
Very curious what the next version will bring us.............
« Reply #44 on: January 12, 2010, 06:02:38 am »
EEeeeeek !!
Standing by to trouble shoot here  scratching
I can imagine the frustration is getting the new version completed, but most advancements in life involve a few backwards steps along the way.
