April 20, 2025, 08:44:40 am *
Pages: [1] 2 3  All
Author Topic: High Frequency Sound while playing (9y-4)  (Read 34837 times)
« on: December 25, 2009, 08:00:22 am »
Wishing you & all the forum members Merry Christmas.
This has happened to me for the first time since using the 9y-4, last night, as soon as I clicked on play, there was a high frequency static sound, I muted my preamp & switched of XX, restarted it & it was playing normal. For a moment I thought I would blow my tweeters.
« Reply #1 on: December 25, 2009, 09:39:37 am »
Hi Arvind,
Did that happen on one channel?
Grtz
« Reply #2 on: December 25, 2009, 05:56:07 pm »
Hi Arvind - Sorry about that ! Never happened to me (if it did I would say it), and I can't think of why it would happen if it is not repeatable. In theory though, after a reboot -when Vista is still busy with other things- I can imagine that bytes get skipped and next are not in line with how it should be (think of audio samples consisting of 2 bytes (per channel) and they should forverer and ever be in the proper sequence. If not, you will receive static. But again, I never saw this happening, and I don't even know how the OS keeps it consistent. IOW, aparently it must be very "difficult" to (internally) skip bytes for audio, but if it happens the situation must be severe (like in out of resources).
Does this happen sometimes to anyone else ?
PS: Please notice that this just can happen in the driver software, and even in the DAC software ...
« Reply #3 on: December 25, 2009, 11:31:30 pm »
I have noticed something similar.
My music server consists of essentially two Vista partitions. One is dedicated purely to XXHE and is very bare. This is the environment I use when listening in earnest.
The other partition is primarily set up for video playback and processing, to which I have added XXXHE. When using XXHE on this partition, I occasionally hear a chirp of mainly high frequency content that lasts for about 1/4 second I estimate. There seems to be a time element at play here though. I may not hear this chirp for an hour or so and it will happen again. Another period of ( lengthy ) time will pass and it will occur again. I haven't fathomed out exactly what is occuring in the system to cause this chirp , but i'm guessing there is some interupt happening (likely lan related ) causing this. If may not occur everyday either. I can't recall it happening on the partition dedicated solely to XXHE playback.
This has only started occurring in recent times though (maybe last few weeks or so ) so I'm guessing it is something on the system that has changed.
I don't believe it is something inherently caused by XXHE itself.
« Reply #4 on: December 26, 2009, 07:29:38 am »
It was in both channels & I doubt if this could be from the DAC & I do use the same DAC with my CD Transport too. Having said that I must repeat that this is the first time it happened playing through my notebook. Since then I have been playing again & it works fine. Just a one of thing, but it would be best to get to the bottom of it. Fortunately my volume level on the preamp was quite low, had it been higher it could have caused serious damage to the tweeters.
« Reply #5 on: December 26, 2009, 11:16:18 am »
I fully agree.
You may email (FileMail) me that track ?
Also, try to have the exact same settings as when it happened before and send the XX and X3 log files after playing that track once more.
« Reply #6 on: December 26, 2009, 11:02:12 pm »
Same happened here tonight,
Had to run for the volume button, almost tweeters gone.
But this happend when the album had already finished and about 20-30sec later,.......RUN!
Very LOUD noise, this is kinda dangerous.
This was the first time, that it happend here
But me stupido, had no logging on, so.......... unhappy
« Reply #7 on: December 27, 2009, 12:52:55 am »
Album ? track ?
« Reply #8 on: December 27, 2009, 12:34:59 pm »
Album ? track ?
John Scofield - 2000 - Bump
But it happened after the last track was finished playing.
Just tried it in Foobar, but it seems to be in the last song. (@ 02.38)
http://www.filemail.com/dl.aspx?id=HOMTMRMWGHYQEIK
« Reply #9 on: December 27, 2009, 01:33:28 pm »
I didn't try it yet Roy, but do you mean it's just in the track ?
« Reply #10 on: December 27, 2009, 01:49:14 pm »
Its in the track.
« Reply #11 on: December 27, 2009, 04:50:55 pm »
The last track 13 is a data track!?! Perhaps this is causing the trouble?
« Reply #12 on: December 27, 2009, 05:17:01 pm »
Yea, I was thinking of that, and have disabled "crack detect"
But anyway, I just cut the song of at 2.36 or delete it at all
« Reply #13 on: December 29, 2009, 08:33:12 am »
I ticked Log File & played the same track which gave the high freq static sound (no problem this time) but I could not find the Log data as there is no Temp Data sub folder. Could you help me with this?
« Reply #14 on: December 29, 2009, 09:06:43 am »
Hmm ... it is called TemporayData and will be automatically created under your current XX folder.
This may not happen when XX is created under \Program Files but if all is right you didn't do that.
scratching
Pages: [1] 2 3  All
Page created in 9.686 seconds with 19 queries.
