November 23, 2024, 05:59:56 am *
Author Topic: Player dont work  (Read 7351 times)
rankena
« on: December 22, 2009, 01:45:03 pm »
XXHE player dont work i n my system.I clicking on all exe files,but nothing happens.Pc spec:Amd Athlon64x2 4400+,DDR2 4gb,Sound-Asus Xonar D2,Windows XP Sp3.
« Reply #1 on: December 22, 2009, 01:54:20 pm »
Maybe this can help you ?
Just the same for xp, start from getting XXHighEnd
http://www.phasure.com/index.php?topic=833.0
rankena
« Reply #2 on: December 22, 2009, 01:56:23 pm »
Thank you again Happy
« Reply #3 on: December 22, 2009, 02:02:38 pm »
Just do some reading, in understanding what to put where.
And selecting your audio-device and music folder.
And use Engine#2, I believe !
« Reply #4 on: December 23, 2009, 12:17:44 am »
Please note that the current version (0.9y-4) is not much good for XP. You really must go back some versions (and I don't know to which one) in order to let XP work stable again. If it works for you, ok (and don't use Double !), but of not, I would start with the last 09x version, and when that doesn't work, try the last 0.9w. If that doesn't work either, please wait for 0.9y-5.
