November 23, 2024, 10:00:10 am *
Author Topic: Settings Problem  (Read 5728 times)
« on: December 20, 2009, 09:44:29 pm »
Hi Peter
I have corruption problems (specifically in unattended mode the album information is not being shown on the screen). Before when I have had problems I deleted everything and started with a scratch install to solve the problem.
I am now trying the same again. I delete everything (the complete xx directory) and then reinstall the software from scratch. However now when I reinstall it the software is finding its previous set up information from somewhere along with the corruption problems.
Given that I have deleted all xx files and directories where would it be picking up the setup information from?
All the best
P
« Reply #1 on: December 20, 2009, 10:50:47 pm »
This should be (explained) in here : How to delete a misbehaving ConfigFile
But I wonder how *that* can solve the corruptions you see.
I can imagine though that these things can happen when you mixed up files from versions ... but you eliminated that for a reason by "reinstalling" everything.
Keep in mind that there is no such thing as a real install. It's just a folder with files you put there.
Let me know what happens with the link I gave !
« Reply #2 on: December 20, 2009, 11:26:20 pm »
thanks Peter that seems to have sorted it
