November 23, 2024, 12:03:10 am *
Author Topic: my core Windows tweaks  (Read 23793 times)
Moritz
« on: December 19, 2009, 08:30:14 pm »
1. I have found that using the SVGA graphics driver over any proprietary driver (ATI, NVIDIA) has a *huge* impact on overall latencies and available I/O bandwidth.
It looks to me that graphics cards have a higher priority than anything else on the I/O bus; so what I have experienced is that when I had issues with glitches in sound quality, these always disappeared after reverting to a standard SVGA driver that shuts down all the I/O intensive GPU work that otherwise occurs.
Of course since this disables video acceleration you will not be able to enjoy high res movies etc. on that machine anymore. So this tweak is quite extreme but the must impactful change that I have found with regards to audio quality.
{how to change: right-click on Computer, -> Device Manager, -> Display adapters, double click the one you are using (e.g. NVIDIA), -> Driver tab, -> Update Driver, -> Browse my computer for driver software, -> Let me pick form a list of device drivers on my computer, Standard VGA Graphics Adapter}
2. Update to Vista/Windows 7. One thing that some people don't realize is that these newer versions of Windows support the notion of I/O priorities. This helps a lot to keep any background activities from interfering with playback. Win 7 in particular also has an improved process scheduler that is more effective than both Vista and XP, in the quest to eliminate jitter you have to take any advantage that you can get ...
to be continued ...
« Reply #1 on: December 19, 2009, 09:22:05 pm »
Nice Moritz, thank you.
I have the hunch that you may know some more things that can be of good help. I hope it's allowed to send you an email about hat.
« Reply #2 on: December 19, 2009, 10:05:23 pm »
Moritz, (price winner?)  Wink
Thank you very much man!! thankyou
Look Below....  Happy
Grtz Gerard
« Reply #3 on: December 19, 2009, 10:38:37 pm »
Aha ! So that is where the standard 1000us is coming from (of which I'm suffering too). I have an nVidia in there ...
Great !
« Reply #4 on: December 19, 2009, 10:41:58 pm »
Great !
Yeah i tried a lot but was out of idears.....  Grin
« Reply #5 on: December 19, 2009, 10:55:46 pm »
And when i change the colors from 32 bits in 16 bits there is also a small improvement.  Happy
« Reply #6 on: December 20, 2009, 10:46:00 am »
No problems over here on W7:
Even using "Aero Themes" with nVidea 9800 GTX.
Is this the difference between drivers or OS ???
I would surely use the standard VGA driver and a vanilla video-card in my
Audio pc, because you don't need it.
But Gerard I bet you get better results on W7.....
Eric
« Reply #7 on: December 20, 2009, 11:07:20 am »
I am also on W7 and I can confirm that there is no problem (similar picture). I do have nVidia driver active, however it looks like W7 can handle it easy. I did switch to Standard VGA but this does not yield any significant improvement in Latency. So I switched back to my full HD resolution mode and I like it a lot!
Cheers, Eric.
« Reply #8 on: December 20, 2009, 11:37:24 am »
That looks different.... Hmmmm think i will get W7 and a ssd for it. Any suggestions for the ssd?
Grtz  Happy
« Reply #9 on: December 20, 2009, 11:43:18 am »
OCZ Vertex 60GB (223,-) or Intel X-25M 80GB  (219,-)
http://www.ocztechnology.com/products/flash_drives/ocz_vertex_series_sata_ii_2_5-ssd
http://www.intel.com/design/flash/nand/mainstream/index.htm
The Intel is even cheaper now, IMO I would go for the Intel.
There is no difference in Q, I guess, so take the cheapest (Dutch) and biggest.
Roy
Do get W7, you may even like it...........
Moritz
« Reply #10 on: December 21, 2009, 03:18:18 am »
it could be that the answer is to use a multicore CPU (e.g. quad core) as an alternate workaround for the graphics driver issue (e.g. fixed affinity on CPU 0).
Cheers, Eric.
rankena
« Reply #11 on: December 22, 2009, 01:12:53 pm »
Im still on Xp :(How maximally tweak XPsp3 for audio max quality?
« Reply #12 on: December 22, 2009, 01:44:36 pm »
Hi rankena and welcome,
Most tweaks work also for xp,
http://www.phasure.com/index.php?topic=548.0
And PeterSt has something special comming for xp-users............in 0.9y5 !!
http://www.phasure.com/index.php?topic=1007.0
If something doesn't work out for you, just let "us" know
And its helpfull to put your devices in your signature, look below ▼▼▼▼▼▼▼▼▼▼▼▼▼▼▼
rankena
« Reply #13 on: December 22, 2009, 01:52:52 pm »
Thank you very much AUDIODIDAKT.
« Reply #14 on: December 23, 2009, 04:09:03 pm »
I also have some issues with latency and i have been told it can be the video drivers.
i'm going to reinstall after holidays and see...
