November 22, 2024, 08:43:43 pm *
Author Topic: XP Users, prepare yourselves !  (Read 32630 times)
« on: December 03, 2009, 10:53:14 pm »
Ha ! that is something new !!
Ok, I got the notion quite some XP users found themselves a tad dissatisfied because Engine#1 and #2 -meant for XP- currently don't workout today as ever intended, never mind those sound engines were a surrogate right from the beginning opposed to Engine#3 for Vista. So I thought to change that ...
I took a rather rough route to make XP Users as satisfied, and created something, well, new;
I challenge you all to guess what this can be, and although it actually is a kind of logical solution, it may be tough to guess knowing the background of XXHighEnd. Just let your imagination roll ...
Allright, the real reason for writing this in advance of the upgrade exploiting it - may be Christmas coming along and some of you intending to get yourselves a Vista box in order to hop over to the ultimate : Engine#3.
Don't.
0.9y-5 will contain a few goodies amongst which the subject here, and since I like to talk in riddles anyway, these are your hints :
  • Only when I'm really enthusiast I mention things in advance (like : can't fail Happy)
  • It is based on older technology, though enhanced by far by me, using the current knowledge of everything (read : couldn't have done that a few years back).
  • It is called Engine#4.
  • All the means of control are equal to Engine#3, hence all the current features and further technology are in there, but now available to XP.
  • Internal latency is better than WASAPI (hence Engine#3, this is to trick the know-it-alls).
  • Of course it is "bit perfect".
  • I may well be that from now on, I myself will be playing through Engine#4; besides all virtues we know to me it seems more analogue !
  • It also can be used on Vista. teasing
Right. I may be wrong on the SQ coming from it, since tonight has been the first night I could play full albums in a normal fashion. But I'm overwhelmed.
There is also a downside :
For starters, Engine#3 doesn't work anymore at this moment. Not intended, but an unforseen combination of things. Probably no big deal, and I will get around that. But besides this, Engine#4 may have drawn too much of my intention, and the bugs in 0.9y-4 are yet still to solve. This means :
Or 0.9y-5 has to wait until everything has settled again which I estimate to be January, or I finisish Engine#4 before solving those bugs, at the same time solving some of those (generally described under "priority problems" - mainly found with Windows7 (and then to think this wasn't tested under W7 at all)). I guess I choose for the first, which may even come down to Engine#3 not being operable in 0.9y-5. I don't know yet.
When this is indeed my choice, 0.9y-5 will be there within a week, the 0.9y-4 bugs being there for 4 weeks or so longer. BUT, it may be so that we all prefer Engine#4 over those bugs, in the mean time helping those with XP.
Anyway, who is the first to guess what Engine#4 is about ?
whistle
Per
Music is forever...
« Reply #1 on: December 04, 2009, 12:05:05 am »
Wow - that would be well received, I think / hope clapping
Will that open up for running XXHIGHEND fluently on Atom 230 (single core) and XP?
My guess would be that you have written an ASIO driver for XP?
Keep up the good work.
Per
Sep 2010
« Reply #2 on: December 04, 2009, 12:11:20 am »
Does this mean the Hiface usb to SPDIF converter will work with engine #4??? Happy (Kernel streaming or direct sound)
« Reply #3 on: December 04, 2009, 06:08:43 am »
Well Per, you are one of the motivators on this one, and I sure do hope so. The single core thing isn't the best because "using all the features from Engine#3" means it is rather based on using processor cores in parallel, but it runs more lean and I'll give it a chance.
Ha ! I only now realize that my HTPC is an XP machine with an 833MHz swoon hyperthreading processor of which the hyperthreading is shut off (making it a single core as how I did it (meaning at the HAL (hardware abstraction layer)). So I guess I can test it myself and (try to) tweak when necessary.
« Reply #4 on: December 04, 2009, 01:40:09 pm »
whistle
I can think only of two things: Kernel Streaming or ASIO. I hope it's not the latter, because I cant use it (until infrasonic writes multiclient asio drivers).
« Reply #5 on: December 04, 2009, 01:57:55 pm »
... to me it seems more analogue !
Compared to Engine#3?
How is this possible?
« Reply #6 on: December 04, 2009, 02:14:51 pm »
Maybe I'm too early with my judgement, but it is fuller, again more tight and pressured bass and something like a better colour. More mid.
It can play inifinitly loud at the same time.
Also, if I look what I did relatively to WASAPI, it indeed would go that direction.
Yes, it is Kernel Streaming, but implemented in a way for sure nobody does / has done. Happy
Per
Music is forever...
« Reply #7 on: December 05, 2009, 03:54:48 pm »
Peter, THANKS A LOT - I really appreciate your attempts thankyou. It will be easier and cheaper to set up a quiet music pc if one can go for a less powerful processor and XP. (I buy one, I will go for the dual core Atom 330 or faster, though - just to have some spare power Wink Keep up the good work. Per
Sep 2010
« Reply #8 on: December 06, 2009, 06:21:51 am »
That looks good Per. But if you are going to buy something, maybe wait what others have to say about it (SQ wise) ?
The upgrade is planned for today. Otherwise tomorrow.
« Reply #9 on: December 06, 2009, 07:34:34 am »
Allright, half of the verdic time has passed, and after 3 days of listening (at knowing I need 5), this is what I can say about it :
It is not better.f:scratching: swoon
It seems I need my room correction stuff again, and I imagine the highs not to be as interesting. Less detail too, I think.
So, standing waves are back again, but ...
Hmm ...
But I never enjoyed music as much as last night !
What ?
Yes; As far as I can tell it sounds more normal. More balanced. As I said earlier, more mid. Less highs. Also more bass, and I'm not sure if it is of the good kind (standing waves). Less detail, it seems.
But it has emotion all over.
Indeed I keep on "hearing" analogue. Including a kind of smeared highs from vinyl. Actually it is the most interesting what actually happened.
And to keep in mind : I may be just wrong. It could be my mood.
But one thing I know for sure : this is totally different, and it belongs in another leage.
It may well be that others (e.g. with good room treatment) even perceive it way better than I do. I think it *will* be so that those seeking for emotion have wet eyes for a couple of albums. For others it may be so that they loose the interest in listening.
Theoretically I belong to the latter group, but I noticed there wasn't time to look for detail and everything, as there was no time to be disturbed by standing waves. Somehow the music is first.
Maybe ... just maybe I only now get what those vinyl freaks find lacking in CDs.
Ok, by now I am really curious what others think.
All is working, but I will need today to finish off other small things like letting Engine#3 work again (for which one day may be too few).
« Reply #10 on: December 06, 2009, 12:46:49 pm »
Am leaving tomorrow morning for work and won't be back till Thursday. Any chance one could preview engine#4 sometime today? Just wondering.... Happy
« Reply #11 on: December 06, 2009, 02:33:10 pm »
Still fighting with the Engine#3 problems ... (YOU know Happy Happy)
One advantage for you : when the day is over here, you have a couple of hours to go ...
Per
Music is forever...
« Reply #12 on: December 06, 2009, 03:08:33 pm »
I will, Peter. Thanks. Anyway - things are progressing very slow for me due to health  Sad
Per
Sep 2010
« Reply #13 on: December 06, 2009, 04:32:13 pm »
Thanks man. You are remarkable.
« Reply #14 on: December 06, 2009, 10:26:34 pm »
No, not today ...
I got Engine3 working again allright, but now see myself (indeed) confronted with audio devices disabled but still selected by KS and more stuff.
It just needs some more time to sort this out I'm afraid ...
sorry
