April 17, 2025, 06:54:36 am *
Author Topic: Wallpaper stopped working  (Read 6165 times)
« on: November 29, 2009, 05:08:58 pm »
Hi Peter, recently the wallpaper with the cover art stopped working here, all else works fine. The wallpaper worked well until I unplugged the laptop, including the external hard drive, and moved it to another room. I opened XX intending to play music on the internal harddrive but forgot to change the music root in xx. The program hicupped and I have had this problem since. Just letting you know. Most of the time the lid of the laptop is closed so it really makes no difference to me.
« Reply #1 on: November 29, 2009, 07:34:24 pm »
Odd ... (which is just something I say if I can't get it, that's all Happy).
Do you still have your normal Wallpaper (when XX doesn't play) ?
If not, you might try to "set" that first.
Otherwise ... in your XX folder there will be (at least in normal situations) a Wallpaper.bmp file. Maybe it got in a read only stage or something. Anyway, if there, you might try to delete it, and try again ?
« Reply #2 on: November 30, 2009, 12:12:01 pm »
The wallpaper, when xx doesn't play, disappeared too when it happened. I had to reset it.
